Another Rookie Question
#42
Just a quick search on Boattrader showed 2 32 Victories for sale. One at Osage Beach in MO, and another in Minnesota. Good luck with your search!
http://www.boattrader.com/search-results/NewOrUsed-used/Type-Power/Category-High%20Performance/Zip-72032/Radius-1000/Length-30,33/Make-Advantage%20Boats/Sort-Length
ESC
ESC
#43
ESC
ESC
#44
I just noticed also, one of those looked nice with HOs, but did NOT have external Hyd steering. This boat really needs ext hyd steering with even standard 496 mags. I saw a 32 Vic about a year ago here on OSO classifieds, but it had 600 Teagues in it. That would probably scoot pretty good! Good luck!
#45
If you are local to the Lake Travis area, feel free to come out and have a look at my 32 Sunsation. I have twin small blocks and do a solid 70 wrapped out. If you found one with 496 HOs you'd definitely have your speed goal in mind.
#46
Also, being in Texas, if you want air flow and still wanting to stay near 60k check out the 288 MCOB made by Sunsation. You'll be towards the tale end of your 70-80mph requirement but there is something to be said about a turn-key boat you don't have to tinker with.
