-   -   Tattle Tale Livosi GPS Question? (https://www.offshoreonly.com/forums/general-boating-discussion/299535-tattle-tale-livosi-gps-question.html)
1sickvelocity 07-10-2013 10:01 AM
My GPS tattle tale Livorsi will not reset from max MPH any ideas or has anyone ever run across this exact issue? The speedo works fine just that I can not reset the max recall any information would be great.
nailit 07-10-2013 11:21 AM
why would you want too? its the max the boat ever went? Unless you repower with Less. You can use iphone app for max speed. I primary use my GPS speedo just reference, also have chartplotter just below to compare.
Do you have a recall button for top speed? Some do, if so you should be able to clear it.. My gps is a Gaffrig and no button. no clue how it resets but it does tell me the fastest the boat went..
beaver 3 07-10-2013 01:20 PM
Maybe he left the key on and then hit the Interstate.
1sickvelocity 07-10-2013 06:06 PM
Haha i was going to say the same thing!
DirtyJerz 07-11-2013 12:21 AM
I would check the connections of the recall wire (I think its the grey wire) and make sure it didn't wiggle loose.
