| low_psi |
07-24-2013 09:31 AM |
The Smaller Velocity's didn't all come with tabs either and heard pretty much the same thing, "they don't need them". I know a local guy that runs his Velocity without tabs, and he says the same thing. However my Velocity is a completly different boat with tabs. They help out in faster planing time, allow to stay on plane at slower speeds (when necessary), allow to plan with less throttle, help greatly when in rough water, help the boat run level when in cross wind or when unbalanced load, and certainly help at full speed when the Velocity likes to dance as the pad gets up on top of the water. But I would agree with others that addressing your prop may be the first step. My Velocity porposes some when I run slow or flat water (it likes to be up on top of the water) with my Bravo 1 prop (designed for bow lift). I changed to a Hydromotiv Quad 4 (designed for stern lift) and it ran much flatter in similar conditions. I ended up back at the Bravo Prop as the minor porposing I have is better than the prop blow out I was experiencing with the Quad 4 prop. The Bravo is a better prop for our daily use... Good Luck and keep us up to date with the changes.
