-   -   496 Water Ingestion HELP (https://www.offshoreonly.com/forums/general-boating-discussion/299998-496-water-ingestion-help.html)
boomer 07-18-2013 07:35 PM
Can I get some help have a 2005 Chaparral 256 with a 8.1 Volvo past couple of ttimes it would stall sometimes coming off plane not all the time but once in awhile. Today it ran great for over an hour then I come of plane and it dies. Locked up solid I know it had water in it so I pull the plugs and water comes out the starboard side second plug from the back. It has the Corsa exhaust but at the time I was running under the water. Non of the pliugs look like i compressed water so I don;'t think I damanged the tops of the piston. I know this can happen did it several years ago with a diffetent boat. So what do you think Exhaust manifold , head gasket ?
I disconnected my fuel pump and cranked it over several times with out plugs. No strange noises. I am going to reinstall the plugs and see what happens.
jvthundercat 07-19-2013 05:39 AM
Lucky if you did not bend a connecting rod. Do you have flappers on it?
