Baja 272 w/ 502EFI won't spin over 4500rpm with Mirage Plus 23
Hi gang,
I'm hoping someone out there had a similar situation and can give some insight to my problem.
1995 Baja 272 with stock 502EFI
23p Mirage Plus
Totally stock boat
Trimmed out, wide open, 55 mph on GPS @ 4500rpm
It seems to run smoothly, no lag or miss. I did a tune up late last season because the wires were arcing.
Shouldn't I be able to turn 5k with this setup, or is it where it should be? I know it's not a 70mph boat, but I thought I would be able to get low to mid 60s.
Thanks!!
Bryan
23p Mirage Plus
Totally stock boat
Thanks!!
Bryan
check your fuel pressure i had a similiar problem with my old engine and it turned out to be pressure regulator how does it do coming on plane mine wouldnt get on plane for crap when i had my issues
www.bajaboatowners.com
How many hours are on the engine? There could be any number of issues. You really need to hook up a scan tool to be able to see what's going on when you run it. It could be a sensor not reading correctly, it could be going into detonation control and pulling out timing, the valve springs could be weak causing valve float, etc. etc.etc.
Eddie
Eddie
You did a tune up because the wires were ARCING?? I would change the cap, rotor ,plugs and check the timing if you haven't as they may be all fouled out IF it was that bad. Do a compression check while you are changing the plugs, you might have a few cylinders just along for the ride and if timing is retarded it might really need a timing chain and or distributor gear. When you did this tuneup did you have the cap off distributor, the 272 Bajas have a problem with water dripping directly on the distributor (rots inside) and coil when people come in and out of the boat swimming and this has caused a lot of problems on mine. The computer isn't going to tell you a whole lot as it doesn't have a 02 sensor or fuel pressure transducer, it will only show a few simple fault codes and they are rarely the cause of major loss of top speed, Smitty
