-   -   Gas (https://www.offshoreonly.com/forums/general-boating-discussion/302622-gas.html)
outerlimits fan 09-07-2013 12:36 AM
Gas
Hi guys, how many people use gas cans to fill their boats or do you use the marina's gas?
Thanks, Michael
glassdave 09-07-2013 06:26 AM
you should be using non ethanol marina gas. if I were at a level the I coud actually use gas cans the few dollars saved would not be worth the hassle or the risk. since I have a two hundred fifty gallon tank theres no way it would ever be feasable.
I keep my Scarab in the water sometimes and I did have a thought about converting a 21 foot Galaxie I also have into sort of a fuel barge. was gonna convert it to an outboard boat and set a three hundred gallon tank under the floor and set up a fuel transfer system. figured I could just fill it, launch it at my marina and raft it off the Scarab and transfer away :D . . . . I weighed out the risks and figured it wasnt worth it either for a myriad of reasons.
Indy 09-07-2013 06:28 AM
You better have some big gas cans...
pstorti 09-07-2013 06:46 AM
my boat holds 300+ gallons of diesel no cans for me
Biggus 09-07-2013 06:50 AM
I've got two 30 gallon gas caddies that I used the last few seasons but pretty much given up on. It's a lot of work, loading up the caddies, driving to the gas station (10 mile minimun trip up here) pump shuts off every 75 bucks.. drive home, unloading a 30 gallon caddy by yourself is a feat and waiting forever for the things to gravity drain. It takes about 2 hrs of my time for only 60 gallons. Just decided to pay marina price and enjoy the boat.
Knot 4 Me 09-07-2013 07:00 AM
It is written into my slip lease that we are not allowed to fuel our boats in our slips and if caught your lease will be terminated. That is why a lot of us that can trailer out boats pull to the local station 10 miles away when the marina gets stupid and wants a $1/gal more for there fuel than what the road stations are charging.
314joey 09-07-2013 07:58 AM
Marina gas or sometimes I have a tanker come by the house if i need more than a 100 gals it's no more expensive, running about $4.80/gal for 90 octane now.
Jupiter Sunsation 09-07-2013 08:17 AM
2 local gas stations here in Jupiter just started selling non-ethanol fuel at the pump. It is about 40 cents a gallon more than 87 making non-ethanol about $4.05. The station that is on the eastbound (towards the ramp) is very tight (unless you are there when the place is empty, you aren't pulling a truck/trailer through there) and the one with great access is on the westbound side causing a trip around the block to get back to the ramp. It would be ideal if they had success with non-ethanol and other stations stocked it since Jupiter has 6 ramps in one park that could handle a couple hundred boats at once.
TylerBurich 09-07-2013 08:19 AM
I use a 50 gal transfer tank with a 12 volt pump in the back of my truck. It's hard to find non-ethanol fuel around here but I currently have a source that is working well. When at loto I just buy marina gas which is non ethanol. My transfer tank is built on skids so I can just fork it out of the back of my truck when i'm done using it. I use it to fill up basically everything that has a carb on it, much easier than cans with the exception of the 2 smoke stuff.
Jupiter Sunsation 09-07-2013 08:26 AM
Funny gas story....
My buddy had a T/S TG and kept it on a lift (no trailer). It would irk him to pay the nearby marina the extra dollar a gallon so he would fill 50 gallon drums in the back of a pickup and drive it home 1-2 miles then he had 150 ft of garden hose to gravity fill the boat. As if a collision risk wasn't bad enough, the risk of torching yourself and/or the boat was simply not worth the savings. He did it for a summer and then came to his senses........worst part was he had the money just too cheap to spend it! 5 minutes in a burn ward wouldn't be worth $10,000 in fuel savings.
