-   -   Cracked Gimbal Ring....How Bad????? (https://www.offshoreonly.com/forums/general-boating-discussion/304244-cracked-gimbal-ring-how-bad.html)
fastdonzi 10-15-2013 07:33 PM
I'm working on a boat and noticed a crack on the gimbal ring (Bravo 1), Right exactly between the two nuts from the U Bolt at the top. The U bolt still has the flat stainless tie-bar piece in good shape. The boat has external Hyd Steering so the inside tiller arm isn't used. The U Bolt & Flat Stainless piece contain/hold the cracked pieces together.. How Bad is It??? Unsafe??? If so, Any chance changing a Gimbal ring without pulling the Motor.
AttitudeJr 10-15-2013 07:37 PM
No the motor does not have to be pulled
VoodooRob 10-15-2013 07:58 PM
Check out JR Marine for gimbal servicing parts, they have done a great job at improving on Mercs wearable parts.
pstorti 10-16-2013 07:00 AM
I believe X-Power drives also makes a solid stainless steel gimbal ring
