why no solder?
Originally Posted by professor_speed
(Post 4024477)
why no solder?
pre-tinned wired is solder coated no?
Originally Posted by phragle
(Post 4024481)
because with solder you are adding another metal. dissimiliar metals and water cause electrolosis and corrosion,
(Post 4024486)
The problem with solder is that if you use the wrong stuff it has acid in it. Eventually that will cause corrosion. If you use pure silver solder then you will never have an issue. The stuff is also very good because it has a lower melting point. I get it from Radio Shack. It is very thin stuff. Once you use it you will never go back to 50/50
I was thinking the same thing I have never had a solder heat shirk connection fail, I have had crimp heat shrink fail though. Just me experience I guess.
The stock wiring for a mercury trim or tab pump is 3 conductors, the power is supplied from the pump end. You don't have to do it that way, just wanted you to know what the stock setup is. Also, I would run at least #10 to main panel. You never know what you might want to add later. Make sure your main feed is fused or has a breaker at the source. Same for the stereo. A short in a heavy gauge wire can get real ugly.
Originally Posted by Mbam
(Post 4024825)
| All times are GMT -5. The time now is 07:52 AM. |
