-   -   GPS speedo hook up/antenna (https://www.offshoreonly.com/forums/general-boating-discussion/305681-gps-speedo-hook-up-antenna.html)
phragle 11-23-2013 08:04 PM
I plan on putting in a livorsi gps speedo. Can I use my chart plotter as the antenna for it? the gps is a lowrance elite and has a NMEA 0183 output.
pstorti 11-23-2013 09:47 PM
only if the Livorsi can connect to the NEMA network and get the speed data from there, it won't get anything from the Garmin. Is the Lowrance elite a gps antenna or a display?
phragle 11-24-2013 06:38 AM
chartplotter
bobbowobbo 11-24-2013 06:58 AM
do you not have the antenna for the speedo?
Dave M 11-24-2013 07:18 AM
As long as your GPS has the NMEA output it should work. I did this with my last boat with a Garmin GPS. You might have to go into the GPS configuration screens to enable the NMEA output. It was NOT enabled by default on my Garmin.
pstorti 11-24-2013 08:03 AM
Originally Posted by phragle (Post 4031916)
chartplotter
it has a built in antenna or external?
troper 11-24-2013 08:23 AM
You should be able too. I did mine to a HDS-7 and it works great.
brian41 11-24-2013 08:29 AM
I have done it on a few boats and it worked fine. Hook it up and have somebody pull you around the block to check results.....nothing ventured nothing gained.
Payton 11-24-2013 08:57 AM
Yes it will work. You just have to set your NEMA output to on and the correct speed for the speedo. I did this with a Garmmin with an intrical antena and it worked fine. I then switched to a Northstar system, it still works the is just a little more lag time for the speed to be sent to my speedo.
phragle 11-24-2013 08:59 AM
internal antenna on chartplotter, no antenna for GPS speedo
http://www.lowrance.com/en-US/Produc...old-en-us.aspx
troper 11-24-2013 09:07 AM
Page 27 says it has an NMEA 0183 output
mcprodesign 11-24-2013 12:02 PM
anybody have luck Replacing the battery in a Livorsi set up. I tried soldering one in and It still doesn't pick up.Kinda hard to get a hold of Livorsy but the said I have to buy a new one.. seems a waste but that's what they said
troper 11-24-2013 02:29 PM
Thats the reason I hooked mine to the Lowrance,
neversatisfied23 03-09-2014 11:18 AM
How do you wire it up? Just picked up a elite 4 and was trying to figure out where to hook up at?
PARADOX 03-09-2014 11:30 AM
I have asked a similar question some time ago (didn't get any comments back :( ) Can I use the Garrfieg Speedo GPS antenna on a Garmin GPS/chart plotter? or the Garmin antenna (internal) on the GPS or on the vessel view?
neversatisfied23 03-09-2014 01:52 PM
My unit says it has the nmea 0183 output but only two plugs on the back for transducer hook up and one for separate speed temp sensor.
troper 03-09-2014 02:01 PM
I have the HDS7 and wired the Lorvisi GPS Gauge to the NMEA183. I'll see if I can find the instructions.
Dave M 03-09-2014 06:12 PM
Yes, You can connect your GPS speedo to your Garmin GPS w/internal antenna. If I recall, the blue wire coming off the GPS harness connects to the signal wire of the speedo.
troper 03-10-2014 06:21 AM
1 Attachment(s)
[ATTACH=CONFIG]520043[/ATTACH]
lastcall02 03-10-2014 07:51 AM
Has anyone ever hooked their Lorvisi GPS to a Garmin 3206? If so, how did you do it?
