Led Lighting
I am looking for led lighting for under my gunwhales in my cockpit, in my engine compartment, and under the lip of my swim platform. I was looking at these http://www.superbrightleds.com/cat/side-emitting/ but was looking for other suggestion. I want to be able to wire them into an accessory switch on the dash.
I have some led replacements that went I to the light pods I already had. They have a good product. And quick shipping
I have some of these under my gunnels http://www.amazon.com/SUPERNIGHT-Wat...led+waterproof they work great but usually start to fail after a year so I have been replacing them annually. The wont last long at all under the swim platform, but will probably do ok in the motor room
I also have these on the underside of my T-top and they are very bright, very high quality and should be a permanent installation. http://www.lumiteclighting.com/produ...op-lights/halo I would go with the strips under the gunnels and the Halo or something else from Lumitec in the motor room and under the platform. You could also use the Halo everywhere and then with one switch you can control all the lights together both dimming and color change depending on the version you get. I have the white, red, blue, dimming version. |
Originally Posted by kevinb230
(Post 4066678)
Originally Posted by pstorti
(Post 4066709)
I also have these on the underside of my T-top and they are very bright, very high quality and should be a permanent installation. http://www.lumiteclighting.com/produ...op-lights/halo I would go with the strips under the gunnels and the Halo or something else from Lumitec in the motor room and under the platform. You could also use the Halo everywhere and then with one switch you can control all the lights together both dimming and color change depending on the version you get. I have the white, red, blue, dimming version. How many strips do you have of these? and how bright are they? |
Lumitec has a great product for a great price.
After reading reviews on lighting and then speaking with a guy at Superbrightleds I went ahead and ordered these:
http://www.superbrightleds.com/morei...light-bar/123/ I will update this thread once I receive and see how they work. |
1 Attachment(s)
I had some waterproof LED strip left over and stuck it to the underside of my platform and ran the wire in thru the cockpit drain thru hull. Didn't know how it'd work or like it, so figured no holes and no cost to try. Been on there 2 yrs now and still going strong. Wired to an empty acc switch on dash
Originally Posted by US1 Fountain
(Post 4066948)
Originally Posted by ealesh33
(Post 4066791)
I saw the supernight ones, and the one reason why i moved on from them is cause they have a controller. As I want to wire these to my courtesy lights switch on my dash, and I just want them to be blue.
| All times are GMT -5. The time now is 05:20 AM. |
