What will 85 extra HP get me?
I have a 2011 checkmate ZT244 with a 502mag 385hp. I'm getting the stage 2 PCM upgrade by whipple. I spin a bravo 1 26 pitch prop to 69mph at 4600rpm. The tune adds 85hp and raises rev limitter to 5400 rpm. How much RPM will I gain with this setup?
Usually takes minimum 20-25 hp per mph so I would guess 3 mph. You might want to reprop because I doubt that extra hp is going to bring the rpms up any significant level if you are trying to spin anywhere near 5400. I would assume that is should be too high on stock 502 because it is past peak hp but whipple is smarter than me and I know there are a lot better people that can give imput over me. Maybe a lower pitch 4 blade will even run it faster based on current setup not even including the added hp. Maybe try a 3 blade m+ 25p. Hope this helps.
Sorry just realized you wanted to know how much rpm not mph. I am guessing less than 400?
I think you'll be close to what livefreeordie says and don't think you'll get to 5400 with that prop......but you have to run it and see. I also don't think your getting 69 at that rpm. Is that speed GPS or dream-o-meter?
Forgot to mention its a raised bravo 1 X outdrive. and the speed is correct. My boat has a GPS speedo and i double checked it many times on my phone and rechecked it with a garmin. I've tried a mirage 25 pitch 3 blade and it sucked, blew out like crazy and had no top end. Seemed to do nothing but slip. I tried a 23 pitch rev 4 which i spun to 4900 rpm at 68mph. Great slip numbers on the rev 4 but the bravo spun less rpm at the same speed.
Originally Posted by t500hps
(Post 4068584)
With the same prop, my estimate is you will be at about 5200 RPM and plus 3-4 MPH.
Originally Posted by BrianH244
(Post 4068528)
Originally Posted by BenPerfected
(Post 4068599)
85 off a tune feels like a pipe dream....
