-   -   Extension box on a single engine cat (https://www.offshoreonly.com/forums/general-boating-discussion/308609-extension-box-single-engine-cat.html)
stoltz 02-14-2014 12:37 AM
All right guys and gals,
I've tried to do as much digging as I could and have not came up with a good answer yet. I was thinking about putting an extension box on my 26' Daytona 3" raise 12 set back. I know there are several out there so I was hoping to see if somebody has any feedback about doing this. "GOOD OR BAD" Thanks for the help.
antisocial 02-14-2014 07:17 AM
I dont know if this helps or not but my daytona with out boxes had problems getting on plane sometimes depending on the wind and waves.. i rode in the same boat with boxes on it and it had no problems getting out on plane. you also might gain or loose some mph.. i would call eliminator and ask them bob leach would be the guy to ask.
johnlomant 02-14-2014 07:59 AM
It works great I had one on my last boat. You have to get the x dimension right tho.
davidwademarine 02-14-2014 08:06 AM
Go for it. We installed several IMCO boxes along with their 2" shorter lower housing on some 26's and a 27' Daytona years ago. They all responded very well, picking up in fuel economy, cruise speed, and planing ability. Some customer chose to re-prop, others were satisfied with their original prop's performance.
stoltz 02-15-2014 12:13 AM
Awesome guys thanks for the help. Did it help with control at tops speeds on do anything to the numbers up top? Seems like it mostly helped out on planning and slower speeds from what you guys are saying. Thanks again for the feed back.
stoltz 02-15-2014 11:49 PM
bump
dnelson964 02-16-2014 11:45 AM
If you get the X dimension right , probably mean also adding a 2" shorty as mentioned above, you should pickup in all categories. But now you are also surfacing the propeller so a propeller change will most definitely be needed to get the added speeds capable. JMO
Tinkerer 02-16-2014 12:00 PM
I built an IMCO -3 / Mercruiser X drive this winter. This will put my prop shaft 1/2 inch above the lowest point of the bottom of the hull. I am running a -2 IMCO right now with a 28 Bravo and 650+ HP at 90MPH.
You say that it helped getting on plane and fuel eff. Was that because the prop shaft was now lower in the water with the box than without? With the box did you go up higher than without?
You said that you had a hard time getting on plane - What was the prop shaft height and what prop?
What was the prop height with the box?
stoltz 02-16-2014 08:51 PM
All good question tinkerer. I also would like to now there they were at before and after that davidwademarine was talking about.
Tinkerer 02-16-2014 09:17 PM
This is my first cat and I have learned many years ago that set up is just as important as HP.
I am trying to do it right the first time. If a box is the right thing to do than I will have to buy one.
I know why you install a box on a V bottom. Higher X dimension, cleaner water, better bow lift.
But - why do you need bow lift on a cat. The air in the tunnel should lift the bow.
On a single engine cat at speed will the center pod even be in the water? If it isn't than the water should be clean even without the box.
I know that the further back the water comes up coming off the boat depending on the speed of the boat. SO further back you get the prop the higher it can be and still get the same bite. BUT how does this help. Couldn't you just mount the drive at the same height without the box and have the same results?
dsmawd350 02-16-2014 09:43 PM
heres my 25 Daytona. its new to me so I can comment on performance with or without. but it used to be a 130mph eliminator factory boat. im sure it has an advantage
http://img.photobucket.com/albums/v6...142453_131.jpg
stoltz 02-17-2014 12:59 AM
I bought one and intend on using it. I could not come up with any reason why it wouldn't work on my setup. I know that when the boat is up to speed there is no center sponson in the water. I have a go pro and have seen that it is not in the water, so cleaner water I don't think is a reason. I feel that I will have better control over the boat for the fact I have more leverage. At east that was my thought. Also I wanted to raise the drive a bit and there is only two ways to do that. Glass the transom in or extension box with a rise built into it. I have already used a 2 shorty on my boat, but still feel like the drive was to deep. Thanks again guys for your input.
stoltz 02-28-2014 11:50 PM
Ttt
JRider 03-01-2014 06:23 AM
With a extension box and raised x there may be more potential for crabbing. I would not do it because I would have to patch holes in my my transom from my rams/lines. I just do not think it would be worth the cost. If planing is an issue I would think tunnel tabs would be a more cost effective solution.
I think it is a good suggestion to call Bob L. You may also want to go over to performance boats forum and ask questions/do some reading as that is more of a havasu cat crowd over there.
PokerRun388 03-01-2014 07:20 AM
My dad had a 1999 25 Daytona, single blown 500HP. He asked the head rigger over at Eliminator several years ago about an IMCO extension box and they told my dad too save his money and that the 25 didn't need it. So he didn't purchase one, although it does look awesome on the transom.:cool:
fbc25el 03-01-2014 08:47 AM
I have a 2000 Daytona twin step with a Imco ext. box and a -2 short lower end. No problems getting on plane and handles well.
stoltz 03-02-2014 01:06 PM
I Have talked to Bob many times about this. He says that some have worked really well and some have not had as good of luck. I am just hoping to find a couple of people that have before and after thoughts about doing it. I know the cost that it is going to take and that doesn't scare me. I just want to make the boat as safe as I can with running over a 120 mph.
stoltz 03-05-2014 07:20 AM
Ttt
stoltz 03-08-2014 12:49 PM
ttt
