Nice, I look forward to seeing your progress on this.
I will post up some pics when its all done, but damn this carpet situation has me so back and forth. It would be easy if I knew what kind of carpet was in there and could just get a piece that matches the current carpet. The blues that are available that are reasonably priced are just not going to work. Plus its going to be about 2-3 days in work to re carpet the whole boat.
Gotcha. Yea it looks like you're doing a great job. Keep the pics coming.
Originally Posted by ealesh33
(Post 4078091)
(Post 4078030)
Ok, yea i was looking at there or behind the controls right above the seat arm in that spot. I wanted livorsi controls, I thought and thought about it and finally decided that money would serve better use in another place and to redo my current ones. I didn't pick up ones for the front up high, just got 6X9's to replace the ones in the boxes under the dash. I have the ability to add another pair of speakers, and if I do more then likely it will be 6.5's upfront like yours
Gel coating that lower part of the seat would be a pain and it would mostly develop cracks unless there was a lot of glass laid on it first.
Have you thought about possibly using a piece of white acrylic or lexan over the front??? |
Didn't know about the pirelli or lonseal till you mentioned. Seems like a good option, but after some research I think that this may not be for me. Alot of back and forth on cleaning, fading, epoxy to use and not to use, how easily it conforms, comfort to walk on. One larger problem is it needs to be warm to apply, and its just not warm right now. I am under a small deadline as my boats time in the barn is running out. Also it can be pricey. I need to get whatever i am going to use here by the end of next week, so I can start doing the project next weekend. Baja uses the color Mariner Blue that may be a match to whats currently in there, which corinthians carries, so was thinking that I could just get enough to redo the speaker panel on the back seat where I need it, well smallest I can get it is 8X12 and at $3.33 per sq ft thats more then to do my whole boat with the other stuff I have lined up. I am really just leaning towards doing the whole boat in the Graphite color. That way the cuddy and cockpit will match, this grey is pretty much the same color grey as my dash mold, and the 2 grab handles for the back seats, so should blend well. I was thinking the grey will make the boat look cleaner, and less cramped with it being a lighter color, as a lighter color makes spaces look larger vs darker making them look smaller. Also by getting rid of the massive amount of blue it will draw more attention or accent the things I want to stick out. The grey would also not be as hot. I am unsure how old the current carpet is, atleast 8+ years old, hell could be original, but the cuddy being a different color is leading me to believe this is aftermarket carpet? so it may be its time to be replaced anyway? I do think the blue looks good, but the question is in your opinion would the grey look as good if not better?
Originally Posted by Griff
(Post 4078148)
Have you thought about possibly using a piece of white acrylic or lexan over the front??? http://i746.photobucket.com/albums/x...BackSeat-1.jpg |
Originally Posted by Orange quatro
(Post 4078140)
Buddy your boat is looking great. Nice work. I will look forward to seeing it this summer. Ill be lurking around the bay.
Im using some diamond plate foam antifatigue stuff on my floor.
| All times are GMT -5. The time now is 01:18 AM. |
