-   -   anyona work at a GM dealership (https://www.offshoreonly.com/forums/general-boating-discussion/309566-anyona-work-gm-dealership.html)
Mseuro 03-11-2014 10:16 PM
I think the factory used Marlboro lights from the factory so the Reds would be an upgrade.
Mseuro 03-11-2014 10:19 PM
could not resist
ratman 03-11-2014 10:36 PM
Originally Posted by Mseuro (Post 4088301)
Ok lol. I think you can take a pack of Marlboro reds and blow real hard while turning the alternator with your tongue. I hear it works real well
naw just busting on ya. my buddy lost his key to his escalade... need help on programing a new key with an imbedded chip...
Mseuro 03-11-2014 10:40 PM
No problem I was trying to be funny. FYI a lot of lock out companies do that now for less and do it faster,
ratman 03-11-2014 10:49 PM
im in medellin colombia... we have no competent lock out companies down here...
Mseuro 03-11-2014 10:58 PM
You have new key? All you need is programming?
bulletbob 03-12-2014 07:14 AM
Thanks for the laughs. I needed it this am!
bajabeas 03-12-2014 10:12 AM
programming one is fairly easy put a charger on the battery as the ign will need to be on for 30 plus minutes insert the key try to start the veh release the key let the veh set until the security light stops flashing repeat this step 3 times should take ten minutes each time in this sequence do not turn the key to off .... the fourth time you turn the key it will start
FIXX 03-12-2014 05:00 PM
and you must wait 15 seconds between key on and key off..ratman you can youtube it,,their are several guys on their showing you how to do it..
ratman 03-12-2014 06:54 PM
thx so much guys
