Eng hatch cylinder help??
5 Attachment(s)
I have 2 engine hatch cylinders that can no longer be repaired off a 1985 12 meter fountain and not sure how to find some replacements? There arent any markings on these cylinders and hoping someone may have an idea on were to find some? Or options with a different style replacement since I assume these are probably obsolete? The have about a 8 1/2" stoke and when fulled extended are 18". Thanks for any help guys! MIKE[ATTACH=CONFIG]520846[/ATTACH][ATTACH=CONFIG]520847[/ATTACH][ATTACH=CONFIG]520848[/ATTACH][ATTACH=CONFIG]520849[/ATTACH][ATTACH=CONFIG]520850[/ATTACH]
CP Performance has them as does Hardin!!
[QUOTE=wieland77;4094980]I have 2 engine hatch cylinders that can no longer be repaired off a 1985 12 meter fountain and not sure how to find some replacements? There arent any markings on these cylinders and hoping someone may have an idea on were to find some? Or options with a different style replacement since I assume these are probably obsolete? The have about a 8 1/2" stoke and when fulled extended are 18". Thanks for any help guys! MIKE
They are the same as the early Merc Hydraulic assist steering rams. I have one nice used one. |
Why cant they be repaired???
Tried to get them repaired but there is a groove in the cylinder, tried to repolish and put new seal in and still leaks. I looked on Hardin and cant seem to find this cylinder Greatguy66 says they carry? Do you know of a part number?
Thanks O.C., might take it if your willing to part with it... just need to find another to match! |
I'll PM you.
OC is correct. Probably a TRS power assist is what it looks like to me.
Originally Posted by wieland77
(Post 4095336)
| All times are GMT -5. The time now is 04:09 AM. |
