-   -   Low of 27 Tonight, Should I do anything??? (https://www.offshoreonly.com/forums/general-boating-discussion/310998-low-27-tonight-should-i-do-anything.html)
ealesh33 04-15-2014 12:11 PM
Originally Posted by Premier Perf (Post 4106758)
I believe 3 people have told you to go put a light bulb and 1 said you should be fine. It's your call but you do have a 3 to 1. Call the marina and have them do it or else if something gets damaged you can't say noone told you but then again im sure you wouldn't say something got damaged. I don't have that problem as i live in Miami. :D... good luck
This isn't the only responses that I have gotten, the OSO family isn't the only people I have asked. Also there were replies in the thread sydwayz posted that said it would be fine as well. Unfortunately the guy at my marina isn't there today. He also said it would be fine, and his sonic is sitting right next to mine which would have the same issue if that says anything. But I am not one to go off one recommendation.
beaver 3 04-15-2014 12:13 PM
I have a space heater with a thermostat i put in mine for these times of the year. It was like 30 bucks at walmart. I set it on 50 and leave it alone. A light bulb will work also.
ealesh33 04-15-2014 12:13 PM
Originally Posted by Sydwayz (Post 4106757)
I wasn't chastising, just guiding you too a very recent similar convo so you could see some relevant opinions. A search would not have found that.
IF it was my boat, and knowing that I have the tiny/thin brass tubes in the very expensive heat exchangers...
...I'd make arrangements to address.
I wasn't sure if you were or weren't honestly lol. I do appreciate the input, thank you
RaggedEdge 04-15-2014 12:14 PM
Early spring of the year will freeze up quicker than late fall. Water temp is colder now and takes less cold air temp to effect things than in fall when water temp is still up there and acts to temper a cold period. Prudent thing would be take a ride or call your marina and have them take care of it.
Dan27 04-15-2014 12:16 PM
I have always heard the rule of 24* for 24 hours before you need to worry about anything. I cannot confirm or deny how accurate that is though.
buck35 04-15-2014 12:53 PM
For future reference you can buy a thermostat plug in that comes on at 35 or so and put a.light on that. Keeps my pump house running and the light doesn't burn 24 7
smckie 04-15-2014 01:05 PM
There is 0.0 chance of an issue. I do an experiment every year. I take a pickle jar and fill it to the brim with water and put a cap on it. It takes several days of far below freezing before it freezes and breaks. We usually hear a loud bang in the middle of the night. My kids tell me "all the boat motors broke last night" One night at 27 degrees is not an issue. If you are still worried follow the others advise. Its good advise!
Sydwayz 04-15-2014 01:38 PM
Fair points, but have you done such with an oil cooler or FWC heat exchanger?
Sydwayz 04-15-2014 01:39 PM
That works great until you have fuel vapors in the boat one time.
They make Bilge Heaters for that specific reason.
Funnone 04-15-2014 01:53 PM
I was always told 24* for 24hrs. 24 for 24
