575sci camshaft question
Ok, so I've tried researching this extensively and there is plenty of info about this on this site, but does every 575sci motor come with a flat cam and lifters stock? The reason I ask is when looking at my mercruiser gm engine identification manual it states states that 2000-2001 and 2002-up are gen VI block with roller set ups. Is this an error in the manual. I'm curious to y they would keep using the flat cams and lifters anyways. If u scroll down u can find it at this URL http://www.marinemechanic.com/merc/d...lockcodes1.PDF
They're all flat cams.
They're already a the limit of an XR drive...the cam is the governor. They respond well to a HR cam |
That's what I thought. I appreciate the reply. If the motors have only very minimal break in time ran on them but have been sitting for 3 years would going through first start up protocol be required again? Or as long as using correct oil should it be fine? Just dnt wanna chance wiping a lobe out....
Originally Posted by Lawless
(Post 4126980)
pump and fire it up right away and hold RPM's at about 1800 for about 10 - 15 - minutes . |
Good info guys. Maybe valve springs need changing also after sitting for 3 years some being in a bind?
(Post 4127003)
I would certainly change the springs, especially if the engine has been sitting and hasn't been turned over in that time period. Some of those springs have been compressed for 3 years. As mentioned, it a damn good idea to get away from the flat tappets if budget allows. You can put a nice hyd. roller in it and really wake it up.
Let me know if we can help. Eddie |
| All times are GMT -5. The time now is 02:42 AM. |
