Need photos of electric fuel pump mounting - Thanks!
I would love to stay mechanical.....But a replacement pump would need the same physical dimensions and the same high fuel flow rate (130GPH/9PSI) as the Mr. Gasket 7732....
Wobble !
You are a life saver! The clay smith pump will work and they claim its a higher flow pump than mr gasket! Same dimensions and i just ordered it!
thanks again!
thanks again!
SORE MEMBER
1 Post
The clay smith may need a regulator to cut it down to 7psi so beware.
SORE MEMBER
1 Post
BTW, the reason I mentioned the Black pump is because you lose significant gph on electric pumps when you pump through a regulator, that is why I like the return style regulator. The electric pump can run at rated output when the demand is there and when it's not it bypasses back to the tank.
Basically the same setup a lot of fuel injection systems have adopted.
This is not such an issue with mechanical pumps though still somewhat true.
