-   -   VP RACING FUEL at the pump (https://www.offshoreonly.com/forums/general-boating-discussion/313621-vp-racing-fuel-pump.html)
Rwbrew3 06-10-2014 10:02 PM
Just wondering if VP RACING FUEL ( think 110 octane ) is better to run rather than the 93 I've been using. A gas station near me just started offering it, now wondering if there is any benefit to using it or will I just be wasting money.
buck35 06-10-2014 10:07 PM
Anything more than a couple points more than your build calls for would be a waste in my opinion, unless you're trying to blend out crappy gas. My 02
Rwbrew3 06-10-2014 10:15 PM
Thanks - was thinking the same thing - think ill run it the first time out this season then back to 93 .
phragle 06-10-2014 10:18 PM
unless your motor is built /setup to run on race gas, you can actually decrease your performance running it.
Rwbrew3 06-10-2014 10:24 PM
Thanks phrase - im not going to mess with it then.. I'm set up for reg pump gas !
mptrimshop 06-10-2014 10:56 PM
Toss a a few gallons in after ya fill up.... Smells good.
Rwbrew3 06-10-2014 11:02 PM
Haha- just heard that from a buddy of mine !!
Griff 06-11-2014 01:09 AM
If your engine is designed tto run on 93 octane and you run 110 octane, you will make less power and it may even foul out the spark plugs. On my 525SC with 8# of boost, I used mix in 5-10 gallons of 110 with the old fuel from the year before just to be safe in case the ocatne deteriorated over the winter.
