Where is Big Dicks located?
Where is Big Dicks in relation to Shooter's?
I wanna say MM54.....???
There's 1 in my pants.........Don't know where the rest of them are:D :D :D
Sorry.....Too easy not to |
In your dreams:D :D :D :D Geeter
I knew that was coming!
Consintracy, I'm not sure which way the mm's run. If you're coming from the bridge to Shooters is it past Shooters or is it the other way from the bridge? |
its on loto:D
I hope you find some and fullfill your quest.:D :D
From the highway 54 bridge it is past Shooters (mm21) at mm 47. You do the math for the distance!! LOL!!! From Shooters you basically just run up the lake. It will make a slight Y sort of, you need to stay in the right arm of the lake. If you do not go under the Hurricane Deck bridge, you went the wrong way!!!! Big Dicks will be on your starboard side back in a cove (I'll bet you turn down the wrong one at least once, right Gordo?!?!?!?!?). Not really that hard to find.
Shouldn't that be "are"??? :D :D :D :D
| All times are GMT -5. The time now is 06:16 PM. |
