-   -   454 with imco powersteering/alternator bracket (https://www.offshoreonly.com/forums/general-boating-discussion/314749-454-imco-powersteering-alternator-bracket.html)
Labattsman 07-05-2014 02:39 PM
Hello everyone, I just had to relocate alternator after rebuilding 454 and setting a weiand 177 blower on top. Blower snout was in the way of stock adjustment bracket. I picked up the imco 04-1360 combo bracket that mounts everything low but it doesn't come with a prefit adjustment bracket for belt tension. It comes with a straight piece of steel with a slot for belt adjustment but isn't exactly bolt on and go. Has anyone else ran Into this issue and what adjustment bracket worked to bolt on and work well?
Thanks for your Input and help
Dave
Young Performance 07-06-2014 12:47 AM
You should be able to make that piece of flat bar work from the sea pump to the alternator. It may need some tweaking, but it should be able to work.
Eddie
