-   -   SHOTGUN Exhaust (https://www.offshoreonly.com/forums/general-boating-discussion/31513-shotgun-exhaust.html)
rick32 08-22-2002 09:06 PM
SHOTGUN Exhaust
Does this change the sound of your engine......?
Rick32
Payton 08-22-2002 09:09 PM
12 guage is a little closer to stock than .410 or 20 guage.:)
Griff 08-23-2002 01:50 AM
If you're talking about Shotgun Mufflers, they will quiet the exhaust down quite a bit at idle and will quiet it somewhat through WOT depending on how you set them.
GEOO 08-23-2002 08:00 AM
I like them. They take the bite off the idle and help stop reversion issues.
Dean Ferry 08-23-2002 08:20 AM
LOVE EM!
They are mechnically simple, NO air pumps, solenoids, wiring, nothing to break. They seem to be well engineered, and I've run my pair for 75+ hours in Salt water with 0 problems.
Hope this helps,
MD
32storm 08-23-2002 09:07 AM
Excellent product with simple design and installation. They do the trick at low RPMS's especially around the dock and in channels, etc. But, as you increase the RPM's, it basically riverts back to a full thru-hull situation. If you do a search on noise, you will find them mentioned in a number of threads.
JON242 08-23-2002 09:13 AM
Love mine too. A little quieter at idle and no RPM loss on top. The only thing I don't like is at idle they make a noise that kind of sounds like a valve tap as the metal shutter slams shut but its not noticable unless the engine hatch is up.
