-   -   99 Checkmate 280 water intake (https://www.offshoreonly.com/forums/general-boating-discussion/315713-99-checkmate-280-water-intake.html)
scottcleaver 07-22-2014 06:56 PM
1999 Checkmate ZT280 with a 502 MPI. It has a raw water pump. Does it have a water grate under the boat to feed the raw water pump or does it start from a impeller driven water inlet in the outdrive?
Scott
RGPIII 07-22-2014 07:43 PM
should be a raw water pump attached to the block thats belt driven. water pick up thru the outdrive, no impeller in the outdrive itself.
scottcleaver 07-22-2014 07:55 PM
Thank you very much
