Originally Posted by Sydwayz
(Post 4158704)
With a pair of 496s, and issues like you describe, I'd invest in the Rinda scanner. www.rinda.com
Money well spent over the long run especially waiting for service in the height of the season. Years ago a guy missed a poker run because one of his 700sci wouldn't come off idle, the culprit, a weak impeller making no pressure at idle. Engine was running just as cool as the other. You also have the option with twins to swap parts, however some sensors are delicate and can be damaged removing them. If you want a guess, my guess is your TPS. If you have a good volt meter you can back probe and test (google TPS volt meter test) |
4bus - Will smartcraft tell you everything that a scan tool will?
Originally Posted by alindquist
(Post 4166567)
(Post 4166567)
Smartcraft does not give you the specs nor the parameters of the sensors or for any fault codes. It will show a fault with a abbreviated listing of that fault code on the smartcraft gauge. Example: ESC-NS POS DIFF - means ESC and neutral switch position fault. You have to learn this abbreviations as well as they are in all the diagnostic service manuals thru the OEM's.
Thanks guys, good to know.
| All times are GMT -5. The time now is 09:41 PM. |
