Goo gone#1
We use commercial grade stuff here at work, but goof off or whatever its called should work fine.
Just follow the instructions on the bottle and do NOT so it in direct sunlight. The sun will make it absorb away before it has time to break down the glue for removal. |
Acetone, carb cleaner, Brake cleaner Goo gone, goof off. Of course you have to watch what U use as far as damaging effects. I think Hardline makes one as well, they are the company that does the # lettering kits. Also some cleaner waxes work real good as well. Collinite cleaner wax use to be good for it but have not used in years. Also a hair dryer to soften the adhesive up first works then a cleaner. Also believe it or not magic eraser works sometimes just as good as anything on some marks and adhesive residues.
super x brake cleaner works like a champ..
Rapid remover from a sign supply store.
Try WD-40. I have had good luck with it on sticker glue.
3m adhesive remover + rubber wheel to soften it up
| All times are GMT -5. The time now is 08:26 PM. |
