motor dies when putting it in gear
500efi bravo drive. All the sudden it started dying when I put it in gear both forward and reverse. Runs fine other than that. Idle is 800 I believe.
Originally Posted by Drock78
(Post 4172773)
i had that problem earlier this year but it was the carb .... does the 500efi have a shift interrupter on it ?
I guess I didn't pay attention to that. I was trying to go through things in my head that it could be.
More than likely, the IAC is either bad or stuck. You can try pulling it out and cleaning it with some carb cleaner. The get gummed up with oil, belt dust, etc. and it makes them stick, especially when hot. Remove the IAC and clean off the pintle (plunger) and the bore that it sits in. It is mounted in the throttle body right on the front of the engine. The IAC is closed when idling in neutral. When you put it in gear and the load increases, the IAC must flow all of the air to keep the engine running. If it doesn't open, the engine will die.
Eddie |
whats an iac?
Originally Posted by stimleck
(Post 4172834)
whats an iac?
(Post 4172834)
whats an iac?
Eddie |
Thanks Eddie. I kinda thought that might be the problem but wanted to get other options before I tore into it tomorrow
If you just left it in neutral you wouldn`t have this problem
| All times are GMT -5. The time now is 06:30 PM. |
