Winterizing sterndrive/engine pink or green antifreeze
#51
Some of the ski boat engine manufacturers recommend this for winter layup.
http://www.tractorsupply.com/en/stor...tifreeze-1-gal
And Merc / Mercruisers take on this. FWIW
http://media.channelblade.com/EProWe...eze%20FAQs.pdf
Also Splash PG antifreeze uses the Dow corrosion inhibitors in which is positive..
#52
#54
I wouldn't use it as a solution for the entire winter, because charred fiberglass doesn't buff out well.
#55
and what happens when electric goes out for days. Last year we had a ice storm and electric was shutdown almost a week straight in the winter with temps never getting over 28 degrees for the whole time.
#56
So you guys are draining everything, then running the antifreeze through, then draining it again so you're leaving just the residue AF in the system for the winter? If so, why not just leave the AF in the system all winter? Corrosion concerns?
#57
^^^^ Some guys do that, using the theory that air doesn't freeze.^^^^
Wouldn't the proper AF solution with corrosion inhibitors would be better than air, because of oxidation?
#58
I have done it once when non-winterized and we geat freak 15-20F night before winterized...but I didn't sleep and kept waiting for the big boom. LOL.
#60
ok let me add another question to the mix.what about corrosion protection with an iron block and aluminum heads?anybody do anything different for that?i been using pink rv anti freeze and so far no problems.aluminum heads are only 2 seasons old though.opinions?freshwater use only.
