382 formula listing to port when in the water >
Like Tree10Likes
Old 10-09-2014, 07:20 PM
Default 382 formula listing to port when in the water
I have a 2000 382 formula that is listing about 2" to port (port side about 2" lower in water than stbd). Batteries and Fridge are on that side of the boat. Do you think it could have come that way from the factory with all that extra weight on the port side? I know that some boats of this model came with Gen and AC on the stbd side so wondering if it was designed to have the Gen on the stbd side and that is why mine is listing.
Hoping to hear from other formula owners that dont have AC/Gen to see if maybe that is just the way the boats are.
What is the best way to check to see if it is 'wet' somewhere ?
poulsen11@yahoo. is offline
Old 10-09-2014, 07:22 PM
Move the fat chick to the starboard side. Problem solved.
phragle is offline
Old 10-09-2014, 07:23 PM
Before moving fat chick you can reach between her legs to see if its wet.
Crude Intentions is offline
Old 10-09-2014, 07:29 PM
just get another large (politically correct) chick to equalize the boat Just kidding dude
abones is offline
Old 10-09-2014, 07:58 PM
The extra chick thing could work......but it could be water trapped in a cavity on that side. Pretty sure Formula is common for that. What about removing the fuel tank access panel for an inspection??
Baja_Bigdog is offline
Old 10-09-2014, 08:00 PM
you could also give it the sniff test to check for rot!
mike tkach is offline
Old 10-09-2014, 08:24 PM
She's ready for her sniff test........
Old 10-10-2014, 04:33 AM
Call Formula...
Rattlesnake Jake is offline
Old 10-10-2014, 08:42 AM
Thanks Mike, will pull fuel tank inspection panel to check for trapped water, although I would think I would have more mold in the cabin while covered if that were the case.
Old 10-10-2014, 09:23 AM
I know of several that do it, mine included. I have a gen /ac and vacuflush, and it still lists a little bit. Pretty normal for these boats for some reason.
RT930turbo is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
