-   -   Heated bilges (https://www.offshoreonly.com/forums/general-boating-discussion/319595-heated-bilges.html)
HEDGEHOGER 10-28-2014 09:26 PM
Heated bilges
Let's hear about what some of you guys have rigged up to keep those big blocks toasty I plan on winterizing the boat this week end with pink -50 antifreeze but was going to add a heating element for some added piece of mind
Cole2534 10-28-2014 09:30 PM
I find that air is great at not freezing in the cooling passages of my engine.
smokin' gun 10-28-2014 09:33 PM
in 15 years ive winterized 1000 s of boats with -50 below pink and they all sat outside never a problem ,I see no need to do anything else
unless your in Alaska .the worst the pink stuff does at - 30 is get slushy .id be more worried if you put a heater or a light bulb in it all winter
SB 10-28-2014 09:37 PM
Use better protection and don't worry about heating it. You'll sleep better.
sutphen 30 10-28-2014 09:41 PM
60 watt light bulb hung in between the engines.
f_inscreenname 10-28-2014 11:00 PM
I bet you live where it gets cold. Asked a guy 15 years ago from Alaska what they did and all he said was, "air don't freeze". Stabal in the gas tank, flush it, fog it, drain it, done
fastdonzi 10-29-2014 08:14 AM
Do Not Add Heat........The cool Metal Engine and Warm air will make Condensation, Everything will Rust, Even if its painted or coated, Trust Me.... I have used Light bulbs & Heaters..Just use Anti-Freeze or drain everything..
s022mag 10-29-2014 08:31 AM
I'm having difficulty locating my port side block plugs on both motors. This weekend it's suppose to get below freezing for 2 nights. In case I don't get my winterization done before should I throw a light in at night or will it take more then just 2 nights dipping below 32 degrees.
Unlimited jd 10-29-2014 08:32 AM
I've been to more house fires caused by heating elements and lights than just about anything else. Make sure your insurance is up to date
sutphen 30 10-29-2014 08:42 AM
depends on the sun and daytime temps.quick answer,you'll be fine.alot of mass to cool.
