anyone know where to get a new GPS speedo like this...
3 Attachment(s)
can't seem to find a replacement anywhere...... sticker inside antenna says Garmin...... if any of you marine parts guys have I'll buy asap......
[ATTACH=CONFIG]532549[/ATTACH][ATTACH=CONFIG]532550[/ATTACH][ATTACH=CONFIG]532551[/ATTACH] |
Hey Johnny, the problem you may run into with replacing the antenna (even if you can find one, which I think will be hard) is compatibility. I had a similar issue with a Livorsi GPS and I needed to replace both the speedo and the antenna because newer antennas will not work with the old gauges. It might be different with Gaffrig, but just double check.
- Neil |
you need the speedo or the antenna? Any gps antenna will work, if you need the speedo that is different.
"IF" you replace your speedometer, don't buy the kit with the antenna. I got a new garmin GPS antenna off ebay for $75.
try kendor in wisc. (greatlakes skipper on ebay) or the marine connection in ft pierce fl
I plan to replace both. I'm not sure which isn't working. I've read here on OSO about changing a battery but I can't seem to find one in the antenna..... Besides its yellowed and looks like crap...... Just easier to purchase the kit and replace whole thing. Any recommendations ? Or links to a good replacement ?
| All times are GMT -5. The time now is 04:02 PM. |
