-   -   Hein-Werner Bumper Jack (https://www.offshoreonly.com/forums/general-boating-discussion/320442-hein-werner-bumper-jack.html)
nordic95 11-23-2014 06:58 PM
Hey guys I just purchased an old Hein Werner bumper jack and I want to make a drive installer out of it. But my question is how do I check jack oil level in this darn thing. Its air over hydraulic and I see the fill plug at the top of the jack. But no other plug to check fluid level.There is a small plug, like a block drain plug, on the air valve assembly but that cant be for oil? No dip stick or anything. I looked all over online and cant find anything about this issue.
Thanks Anthony
akaboatman 11-23-2014 10:02 PM
I can't help without a picture. All hydroic jacks have to be filled in the down position. Hope that helps.
Sydwayz 11-24-2014 08:15 AM
My friend "G" found some great info for you:
http://lmgtfy.com/?q=hein+werner+bumper+hydraulic+jack
http://www.garagejournal.com/forum/s...d.php?t=208722
http://www.garagejournal.com/forum/s...53#post3068953
F-2 Speedy 11-24-2014 08:24 AM
[QUOTE=Sydwayz;4224447]My friend "G" found some great info for you:
Impressive
1 MAIDEN AMERICA 11-24-2014 09:37 AM
Most jacks get filled to the plug while in the lowest position.
You'll probably want to put a regulator on it. When going up, they start slow then GO.
nordic95 11-25-2014 08:46 PM
3 Attachment(s)
Here is the jack. Oil fill on top and no other plugs on the jack. Looked in thru plug and oil is down about two feet. But jack works fine. I can't see filling this whole cylinder with oil.
