Can you identify this transmission?
1 Attachment(s)
Hi folks ,
Maybe a easy question but... From the photo.. can you identify what transmission is connected to this motor? Also would anyone know anything about this type of transmission ? The engine is a big block mercury racing motor from approximately 1990. thanks a million! [ATTACH=CONFIG]535035[/ATTACH] |
it is a plug in trans,looks like a bam marine.
Originally Posted by xxxxxxx1
(Post 4242257)
Hi folks ,
Could be a stock Borg 72c, looks like the engine is a 420 merc
The transmission ID plate should be located if I remember correctly under the starter (left side, on top of the trans) ?
next IMO it looks like what merc use to call this transmission a Velvet Drive (Borg Warner 72 CR) could be wrong - going back some years now, off the top of my head. If the trans ID plate is under starter it should have listed the Model #, gear ratio, serial # and ID plate model color code if any of this is still readable. |
Originally Posted by BUP
(Post 4242317)
next IMO it looks like what merc use to call this transmission a Velvet Drive (Borg Warner 72 CR) could be wrong - going back some years now, off the top of my head. If the trans ID plate is under starter it should have listed the Model #, gear ratio, serial # and ID plate model color code if any of this is still readable. This velvet drive...is it a good trans?.. great type of unit? ...common application ?.. Thanks so much for your expertise everyone. |
Yeah kinda common. Like every boat with Ssm, 3,4,5,6's unless they have crash boxes, and any tr or trs boat with a 370,400,420 or bigger power.
