-   -   CMI Headers (https://www.offshoreonly.com/forums/general-boating-discussion/32276-cmi-headers.html)
baja bailey 09-03-2002 11:26 PM
CMI Headers
Anyone had a set of CMI's with any age on them? I have a friend who was thinking of buying some, but we were told by a guy they have a bad habit of cracking...He said even the new ones with the cool callar crack? Thanks!:confused: :confused:
puder 09-03-2002 11:37 PM
first i'm hearing of that I though it was really old stellings you stay away from?
I know the navy uses the CMI tube tops for the SEAL boats so i would think they are pretty tough.
Dave F 09-04-2002 06:21 AM
Never heard a problem with CMI's. I had a set for 5yrs. Like Haveit said, the worst problem was that rope gasket.
When I sold the boat they still looked great.
I have heard of problems with Stellings and Bassett however.
DAVE
mcollinstn 09-04-2002 06:31 AM
I bought a set of older CMI's for installation over the offseason.
Who knows what the BEST material is for the rope seals?
I hear folks mention fiberglass rope. What about some of the new teflon impregnated shaft log packing material? I guess its gotta be pyrex or some other heat resistant stuff, eh?
Comments?
GotTheFever 09-04-2002 08:56 AM
My CMIs are 8 years old, with 300+ hours. No problem except that I can't keep the silent choice working.
mr_velocity 09-04-2002 09:32 AM
I've never had good luck with the fiberglass rope seals, they always leaked after a few hours. I think it is the heat. I found some graphite rope at MSC, one day I'll give that a try.
Dave F 09-04-2002 10:01 AM
I've already tried the graphite rope. The only thing it does is cause the engine compartment to turn black and put a "dust" all over everything when they start to leak.
Just my experiance.
DAVE
BLOWN 1100 09-04-2002 02:22 PM
CMI will sell you the ropes, give them a call.
Mr Gadgets 09-04-2002 04:38 PM
baja bailey,
I aquired several sets of the Navy Seal Tube tops. Some had pin hole leaks and I had them welded up. I cut the uppper tubes to make them fit my 25' Convincer with narrow exhaust outlets.. Since then I have reused the bottoms and bought new uppers for my 28' Checkmate.
As for the rope seals, I have had very good luck with the furnace door type of packing. I use a smaller dia of rope.. about 3/8" and the trick is to wrap the rope about the pipe several times and pack it into the clamp.. I did this the last time and I have no leaks.. the ones they sell need to be sealed at the ends. If you wrap four or five times.. there are no ends to seal...
I would buy CMI's again in a heart beat. You are advised to psi check them for any type of leaks before paying for them..
good luck
dick
BuzzinBye! 09-04-2002 06:20 PM
I have all you guys beat!!!
6 years on my CMI headers
610 hours
3 sets of rope seals
no cracks
gotta love'em
would absolutely buy them!!!
Dan
mcollinstn 09-04-2002 07:55 PM
three or four wraps!!
That sounds like the ticket.
