-   -   Thought I would post this for fun (https://www.offshoreonly.com/forums/general-boating-discussion/324461-thought-i-would-post-fun.html)
F-2 Speedy 03-26-2015 11:12 AM
1 Attachment(s)
Standard BBC cam on the left.............. 60mm billet core on the right
payuppsucker 03-26-2015 12:52 PM
Looks like a Bob M special. Mine had that same copper colored plating on it. Any idea why it's on there?
F-2 Speedy 03-26-2015 02:23 PM
The 60mm cams went in my bud's new motors
OLDRAT 03-27-2015 08:46 AM
Pay,
It's on there to prevent heat scaling during the heat treat process.
OR
payuppsucker 03-27-2015 12:31 PM
Thanks for that info OR. I'd never heard anyone say and I've only seen it on the billet pieces. I suppose the cam is ground after the heat treating?
rmbuilder 03-27-2015 02:18 PM
Originally Posted by 33outlawsst (Post 4284134)
Standard BBC cam on the left.............. 55MM billet core on the right
Ken,
The cam is a 60 MM, 2304, vacuum degassed, carburized ,AQ, 8620 billet core.
Weapons grade
Bob
F-2 Speedy 03-27-2015 02:42 PM
Thanks Bob, I corrected it, I'll touch base with you first of next week,...... the point of this photo is to show how massive the core & journal size is, compared to to the OEM.
OLDRAT 03-27-2015 03:53 PM
Yes, ground and finished after final heat treat. A thin copper plate prevents having to grind through a carburized layer which can be somewhat thick. The plating would not be necessary if one used a vacuum furnace to heat treat but it's somwhat more costly.
That cam is a sweet looking part and like Bob said, strong and bulletproof.
OR
43sv 03-27-2015 07:48 PM
I have put the 60mm in my motor but I used tool steel, Tommy from Cheif got them for me he claims they are strongest you can get and dont wear at all, seem to run good. Very expensive
