Gas struts or hydraulic engine hatch lift
1 Attachment(s)
Need your ideas. Rigging the 37 scorpion, built offshore race hatches. Which should we use for lifting our engine hatches. What are the pros and cons of each.
its really tough to beat the simplicity of power hatch lifts seems most side by sides do use struts though.
power lifts pros - well . . . ya push a button an they go up . . . thats it cons - ya gotta buy and install two of 'em struts pros - cheaper and easier install cons - no "one button" to push while your sittin at the dock trying to look cool :cool: :D I would probably use two smaller power lifts or maybe build some custom hydraulic ones. I always thought older Merc MR (pre Alpha) trim ram cylinders could be used in some creative ways like this. Long throw, fairly cheap and easy to find plus there pretty strong. Early MR rams are smaller around then later Alpha/Bravo variants. |
What's wrong with an electric actuator? No hoes or oil to mess with.
I was going to do hydraulic rams on the hatches I built. I bought the rams, extra pump, and all the hoses and there they sit in the garage. Never got around to installing them with all the other projects I have going on. So I installed gas struts on the backs of the hatches and they work really well.
[img]
Measured the area. Seems like we need an actuator that's 41" closed. The longest I've seen is 31" (CP performance). May need to fabricate a 10" bracket? Seems so.
Originally Posted by Cole2534
(Post 4292785)
1 Attachment(s)
Originally Posted by sonic700
(Post 4293027)
[img]
Thanks buddy
Broom stix's!!! bla hahahahaha..
| All times are GMT -5. The time now is 02:54 AM. |
