Cat Owners .... Help
Old 09-08-2002, 09:56 AM
packinair
Default Cat Owners .... Help
I have twin o/bs on my cat and they are in the ccenter of the tunnel instead of out on the ends like alot of cats.. I just went from 15" mids back to 20" mids because I was getting to much prop chatter and snapping driveshafts.I put everything back togeather yeasterday and when I took it out the boat pulls to the left VERY VERY hard. to the point I could hardly hold it.. I have manual jack plates so I jumped in an raised the left motor about an 1".that helped alittle but that motor is still higher than the other.I also have a twin cable steering , that yes I know I should put hydrolic on so if anyone wants to divy up the cah for I woyld be more than happy to install it. any ideas before I wind up on my head? ?????
Old 09-08-2002, 10:06 AM
Gone Fishin'
Waterfoul's Avatar
Do your props counter rotate?????
[b]M Go Blue.......Gator boots, gator luggage, gator purses... all at cut rate deals!!!!
Waterfoul is offline
Old 09-09-2002, 08:45 PM
MoneyShot
Are you turning counter or not? You need to get off your wallet and get in control man! You've got a death wish in regards to your steering,( or lack of) if your set up is even near correct- there should zero pull. Both cancelling each other out- please have more regard for saftey and change your steering system. The other question- why are your motors placed in the dirtest water in the tunnel and not space out from each other? What type of boat?
stangjeeper
Advantage
14
02-16-2008 08:00 PM
Wally
10-23-2006 10:05 PM
Wildchild212
12-05-2004 04:41 PM
Semper Fi
06-09-2004 01:59 PM
MnFastBoat
Eliminator
12-14-2003 12:40 PM
Quick Reply: Cat Owners .... Help
