-   -   Cleaning Stainless props (https://www.offshoreonly.com/forums/general-boating-discussion/325845-cleaning-stainless-props.html)
redwhite 05-04-2015 10:39 AM
My props have that hard calcium type of scale on them. What is the best way to clean them off? Is there a liquid/chemical solution that can be used as opposed to an abrasive approach such as scotchbrite?
ohh wow 05-04-2015 10:41 AM
Polishing compound on a buffing wheel.
PARADOX 05-04-2015 10:54 AM
Light mix of muriatic acid or wood chlorine. If it's mild. that stuff you use in toilet works a bit too.
apex svt 05-04-2015 10:55 AM
Try lime away, works,or sulfuric acid. Be careful though stuff is tough but cleans stainless well
Gunrunner72 05-04-2015 11:19 AM
Stick them in a 5 gallon bucket with some vinegar and let them soak for a while.
3pointstar 05-04-2015 11:33 AM
Any cheap toilet bowl cleaner
3pointstar
RaggedEdge 05-04-2015 11:34 AM
On and Off bottom cleaner works like a charm.
Kelly O 05-04-2015 04:11 PM
A sponge soaked in CLR cleaner will melt that right off. Works great for getting baked-on scum off exhaust tips as well.
rfgonzo 05-04-2015 05:01 PM
^^^^^ This,
Powerquest230 05-04-2015 06:47 PM
Rinse props with Snobol, lime-away, or your pick of acid and then run through a full cycle (air dry not heat) in the dishwasher when the wife isn't home. Don't forget the jet dry and then polish.
