-   -   Lake Cumberland - Towing/Transmission Issues (https://www.offshoreonly.com/forums/general-boating-discussion/326552-lake-cumberland-towing-transmission-issues.html)
BarometerSoup 05-24-2015 08:38 AM
Went to pickup my boat at LCM this past week to spend the weekend at Lake Cumberland. My tow vehicle is a 2007 Yukon Denali XL with a 6.2L and 6-speed auto. Never had any trans issues and the truck usually pulls the 4000lbs boat/trailer like it is not even behind it.
On the first day I hit Lee's Ford and got a weird grind noise down the hill for less than 10 seconds (didn't sound like brakes and all 4 corners are brand new). Truck seemed to struggle getting the boat up the ramp, but made it to the top. I don't usually put in on that steep of a ramp; however, I was surprised to see the truck struggle considering the power to weight ratio.
Day two towed the rig over to Grider Hill and started to head down the lodge ramp by mistake. When I went to backup on the hill with the trailer, the trans kept slipping out of gear and I couldn't move it. Just before we stopped to back up I once again heard the grinding noise. Had everything towed to flat ground and I disconnected the boat. With the boat off I was able to drive the Yukon back to Ohio (5 hours) with no issue and no slippage even on some larger grades.
Anyone had a similar issue on one of these trucks? Is this simply a worn transmission, or likely another issue (electronic control, etc.)?
Also, any recommendations for a less steep ramp at Cumberland? Regardless of if I get the truck fixed, I managed to scare the crap out of out my wife so if I want to hit Cumberland again I am definitely going to need a less steep ramp. Thoughts? Thanks.
ImaPoser 05-24-2015 07:53 PM
Conley is the best marina ramp I've used. Burnside island if no marina services are needed.
1 MAIDEN AMERICA 05-25-2015 09:59 AM
6L80E trans problems
The 1234/35R clutch drum cracks and can cause slipping. I'd guess that certain torque loads/temp would expand the crack and let it slip at times.
The stator support/pump also have updated sealing rings to help a poor seal/slip/flare problem.
The noise could have been a clutch chatter and/or valve buzz from a pressure instability due to a leak.
There are also valve problems and a few other things.
http://c.ymcdn.com/sites/members.atr...6L50-80-90.pdf
Even if it's something totally different, get the lates trans computer program installed. It helps a lot.
chattviper 05-25-2015 03:02 PM
Put in at the damn. Much easier.
JRider 05-25-2015 06:20 PM
Might be a good time to trade it
ALL_IN! 05-26-2015 03:00 PM
This...
TBAG 05-26-2015 04:41 PM
yup
BarometerSoup 05-27-2015 12:11 PM
Thanks everyone, great information. Turns out the truck had a bad MAP sensor and it was freaking out electronics under load. Manifold was dumping the power making it feel like slippage under load. Dodged a big bullet on this and got away with a quick sensor replacement.
I'll definitely check out the dam and Conley for launching going forward. After the last experience it's going to take some convincing to get my wife back on a launch ramp.
ALL_IN! 05-27-2015 12:53 PM
I hope the launch was not a deal breaker for your wife. It is a great lake, and water is very clear.
Tell her that her bikini's will be much cleaner there than in a river somewhere! :-)
My wife loves that lake, but nerves/tensions do get high around the ramp. (she drives the truck / trailer and I handle the boat).
92nsx 05-27-2015 01:07 PM
As long as you dont get the dreaded P0010 or P0011 code. That code can be worse then the ex.... Man I have heard some horror storys with that. Crossing fingers it dont happen to my 6.2 esky.
beaver 3 05-28-2015 01:50 AM
the damn is awesome. if its not busy i'll drive head first all the way to the water and pull a U turn, and then back down. the walk back up it sucks at the end of the weekend though,
TBAG 05-28-2015 07:06 AM
Not half as bad as the walk up to the lot @ Jamestown if the shuttle isn't running. :mad:
Budman II 05-28-2015 08:32 AM
Yep, that might be the best thing to come out of the dam repair project, aside from less chance of the dam bursting. :eek: The new ramp over there is a quantum leap improvement over the little two lane ramp that used to be there. Parking is much better too. IMO, it is the best place to launch on the lake.
BarometerSoup 05-28-2015 03:08 PM
Are there plenty of courtesy docks around the ramp? I always like most of the Cumberland marinas since they have plenty of places to put the boat once you launch for a few minutes.
chattviper 05-29-2015 07:06 AM
https://www.google.com/maps/place/Wo...5e3b8f!6m1!1e1
Have a look yourself! :)
I use google maps all the time to map out what ramp I use. Use the satellite view and you get great detail. Since I'm pulling over 60 feet I have to plan my launches!
TBAG 05-29-2015 10:52 AM
No, just a small dock on the right side. Nothing at all compared to the large docking space around the marinas launch ramps.
