Bouncing oil pressure...
Some small blocks have the oil psi sender just behind the intake manifold and in frt of the distributor. The intake almost touches where it is screwd into the block.
The later small blocks usuall have it here #17:
Update this for the fix and problem. THX
Also asking does your oil pressure gauge increase sporadic (bouncing) readings while you trim the outdrive(s) If so then you have wiring problem of some sort. Grounds included to.
I hear you about bad or even loose connections even jumper in series from one gauge to the next being installed. Like I asked if your oil pressurereadings moves or drops when you use the trim - you have some sort of wire problem - resistance, corrosion or loose and or bad ground(s)
One of my eng's did the same thing for 2 seasons- steady pressure at idle up to 4500 rpms then it would bounce around like crazy. Replaced sender and gauge- no change. Put a mechanical gauge on it and it was fine so I just lived with it. Last weekend I was working on some other issues and ended up moving around and disconnecting/ reconnecting several of the wiring harnesses. When I ran it after that, I had steady pressure for the first time in 2 years.
