Originally Posted by superderek3
(Post 4368234)
I'm not trimming out once on plane .
that's probably my only problem - if that works then i'll likely get into my RPM range as well and all will be good.
(Post 4368234)
I'm not trimming out once on plane but now recognize it's something i should be doing. I'll need to experiment with it. Boat is now winterized so it'll be a while till i can come back with test results.
With trimming the boat hits 60MPH - much faster, @4400RPM!
You need smaller props and more rpm. I 'd try 23 Mirage plus'
I'd wait for him to have a little more seat time. Thi is his first time running it since being told about trim. Outdrive trim that is.
Would smaller props make sense? I think these motors are rated for 4200-4600. 23p would probably put me over 4600 i'd think
Everyone needs some trim... bro trust me on this...
Do you keep it in the water? Has the bottom been painted? Whens the last time the engines were serviced/tuned up? You using speed wax? |
(Post 4431260)
Get some more seat time and see what you get with it trimmed out for max speed. |
| All times are GMT -5. The time now is 11:20 AM. |
