Goodwin-Powered Outerlimits Upgraded with New Chartplotter, Engine Monitoring System
Northern Michigan's Peter Oppermann pulled off this cool project to be able to read data from his custom Goodwin engines on the new chartplotter he installed in his Outerlimits V-bottom.
http://speedonthewater.com/boat-rest...itoring-system |
anyone interested in the noland upgrade feel free to ask questions here
What would it take for carbed blower motors?
Originally Posted by Pokher Ace
(Post 4343905)
You can also run it to any sensor without a gauge and get a reading on the noland. You do need to know the specs for the sender to calibrate the Noland for the correct range.
If I read the article right doesn't it end up as a NEMA 2000 message?
It could interface with any NEMA 2000 compatible device then right? |
(Post 4344156)
Are there in dash mounting options? Larger display options? Cool project Pete!
If I had a 12" display and 2 nplans boxes I could run 6 gauges each engine correct?
Originally Posted by Unlimited jd
(Post 4344272)
Originally Posted by TCBoss302
(Post 4344266)
And Jd you are correct and with 2 units you can have 12 gauges and 2 tachs or 3 if you had trips. I did oil pressure, oil temp and engine temp. |
As an FYI one thing I would like to explore more about the simrad units is mine has built in wireless connectivity and can be controlled on a tablet thru an app. I also think it can be connected to multiple tablets at once. Not sure tho but I think it would be cool to use a tablet mounted to the back seat for passengers to see everything I see. Or maybe my co pilot. But this all comes back to what tablets can you see in the sun.............
Originally Posted by drpete3
(Post 4344173)
yes thats correct. I think this is a cool add on to any older or custom motor.
Nice article Jason! I like this kind of stuff. |
(Post 4344341)
Nice, and just down the road from me.
Nice article Matt! I like this kind of stuff. |
(Post 4343675)
Originally Posted by jrz
(Post 4344385)
with late 90's mercruisers, could you use the plug for the scan tool and maybe readout fuel used?
Nice job drpete3. The Simrad and Raymarine units both have built in WiFi connection now. I can see it being handy on a bigger boat where you want to monitor engine or chart data on a tablet in the galley. But in direct sunlight, ya need something like a Simrad monitor to see anything... Does their app offer any data logging options? |
Originally Posted by kidturbo
(Post 4344620)
Your talking about early MEFI units? If so it's possible, but with a different device. That's known as serial data, this device does analog like voltage and resistance values.
Drpete3 what is the app used?
Originally Posted by 111scoundrel
(Post 4344781)
Correct me if I'm wrong here Drpete, but if you have an EFI motor (or smartcraft) you could use one of these Livorsi Data Gateways to convert the ECM data to NMEA 2000. Then you should be able to display anything your ECM monitors (boost, IAT, fuel px, etc). Does the Go7 give you the options to display any of these parameters?
http://www.livorsi.com/catalog/mefi.html |
Originally Posted by ToMorrow44
(Post 4345190)
| All times are GMT -5. The time now is 07:02 AM. |
