Like Tree0Likes
What oil pressures do your 800's ,900's 1000's etc. run ??
Old 09-15-2002, 10:53 PM
bob
Charter Member #40
My Boats: Renegade 32
I run KE's system which has a belt driven external pump. KE recommends 10psi/1000 hot. Thats what I run with a petroleum based oil and all has been good!
bob is offline
Old 09-16-2002, 11:20 AM
THanks guys ! I have Melling pumps on my 1000's. I don't have restrictors to the top end . I have herd all different stories about that . I think the springs need oiling . I am in the final stages of getting them ready to go out for testing . I only had them running for a minute or 2 as I had a cooling problem ( NO WATER ) . I know it had pressure but not sure how much . I would guess around 40-50 with 20 /50 racing oil cold.
boot is offline
Old 09-16-2002, 11:26 AM
Rob
Trade Score: (6)
Strip Poker 388's Avatar
My Boats: Hustler 388
the motor that i had built by jim oddy ran93 psi on the dyno in the boat thru the coolers and stuff was about 70-75 and hot was around 65. the reason that they gave me for the higher pres was the give more cushion on the bearrings. but need a good oil pan for the windage. ran 150 hours before tear down . was a 496 at 12 psi at 828hp.
Strip Poker 388 is offline
Old 09-16-2002, 01:37 PM
Rob, What kind of blower do you run ? Not that it matters . I'm just wondering with that boost . THanks !
boot is offline
Old 09-16-2002, 07:07 PM
H2Xmark's Avatar
My Boats: 1997 Fountain 35 Lightning
Is Oddy still running the drag racing circuit, with the pro modified cars? he builds a mean engine, I know he use to build some engines for some of the Alcohol funny car teams
H2Xmark is offline
Old 09-16-2002, 09:56 PM
I think he still runs .
boot is offline
Old 09-17-2002, 03:57 PM
Rob
Trade Score: (6)
Jim Oddy ha s the fastest pro mod mph 230 something .fred hahn is the driver.oddy uses bds. i allready had built the motor with the littlefield. boot the blower is a mert littlefield stage 3 8.71 with the hard anaidized inside with the tef. strips. had 2 1050 dom on it ran at 8 % overdriven around 12 psi thru the supperchiller. never had any detination , no speckling on plugs.this was a good pump gas motor..sold that boat and kept the motor plan on puting in my 69 camaro . send blower back to tighten up , put in a soild roller turn up boost on race gas, and see what it will do then.
Old 09-17-2002, 07:37 PM
Rob , Looks like you and I are going oposit ways . I gave up the street/track to go full "blown" into the boat thing ! MY girl is a big Camaro fan so I'll probably end up with a 67-69 in the garage for her soon ! I have 8-71's on the boat too . They are BDS, but have Littlefeild stickers on them ? I bought the boat that way . IT is suposed to be set up for 8-9 psi. I haven't even seen that much . Allthough I have very limited time in it due to problems . Hopefully I'll get it worked out soon . Thanks for the info.Maybe when I get the bugs worked out I'll mix a little race gas just to be safe and turn it up to 12psi !!
boot is offline
Old 09-20-2002, 07:21 PM
Rob
Trade Score: (6)
boot i sold the scarab to get the 388 hustler that i have now , plan on supercharging them later.so im still playing with both the cars and boats.got to something in the cooler months. fixing to start drag racing the camaro soon then when its to cold i show it and the 70 chevelle.there allways something.
Back4More
1
01-17-2006 04:40 PM
baja_daddy
09-27-2005 03:00 AM
Jonas
12-31-2004 10:23 AM
Johnny DCB
07-13-2004 03:11 AM
blown formula
11
03-19-2003 10:43 PM
