-   -   Opinions on 2000 Sunsation 288... (https://www.offshoreonly.com/forums/general-boating-discussion/330312-opinions-2000-sunsation-288-a.html)
lab85 08-31-2015 12:51 PM
Hi All,
looking for opinions on a 2000 sunsation 288, 454 mag mpi w/ approx 400h. Is this engine adequate power for his boat? also, would $35000 (canadian) be too much to pay (or fair)? how does it handle rough water as I will be running it in the atlantic ocean (east coast)?
Thanks in advance!
lab85 08-31-2015 01:23 PM
*I was referring to 400 hours when I mentioned "400h" above
fasthawk6 08-31-2015 04:49 PM
I don't think I would by a single engine boat to run in the ocean!
JRider 08-31-2015 05:56 PM
It will hammer $hit out of you in the ocean.
lab85 08-31-2015 07:32 PM
What would you guys recommend? I would like a single engine boat in the 25-28 foot range as they typically weight less and will be easier for trailering. I have looked at a donzi 26zx with 500 EFI as well.....
Jupiter Sunsation 09-01-2015 08:49 AM
288 is a nice boat. It has a pad so it will be a little rougher than a non pad but it will be faster because of it. Also keep in mind the 288 is the same boat as the bigger 32 from the dash to the transom. You will have to pick your offshore days but it isn't a bad choice to start with.
lab85 09-01-2015 09:55 AM
Thanks! I will be using it in coastal bays as well as in open water, so like you said I will just have to pick my offshore days. Is the 454 mag mpi a good set up for this boat/entry into performance boats?
Jupiter Sunsation 09-01-2015 09:58 AM
Yes good motor to start with but it is still almost 16 years old so at some point it is going to cost you
93 shooter 09-01-2015 11:48 AM
asking your option,is there a big difference in the ride in rough water (ie: lake Erie)in non pad compared to pad. assume that baja's 27' do not have a pad.i also have been looking for a 288,but have not taken a ride in one yet
SC288 09-01-2015 02:38 PM
Not sure what year 288 JRider had....sounds like he has some good experience running a 288 on the East Coast. I ran my 99' 288 on the South End of Lake Michigan for 3 years and it did pretty well in decently rough / snotty water for it's size....then again it is just a Lake right? There are some other options to consider like the 25' or 28' AT, 28' Pantera etc. etc....
