Originally Posted by bck
(Post 4359143)
Can't really get much closer with the transom assembly's. I can measure whatever you want. Mine is about as tight as you can get.
What kind of boat is that?
Originally Posted by indysupra
(Post 4359176)
1 Attachment(s)
[ATTACH=CONFIG]545729[/ATTACH]
I'll be able to measure it in the next couple days
Thanks bck also if you don't mind can you measure from the front of the lower pulley of the rear motor to the same spot on the front motor .
Cheers RG. |
The engines are out right now. That's how I can get all the other measurements. The front and rear motor mounts and bellhousings are in it, but no motors.
Okay how about motor mount distances rear motor to front motor front mount on each motor .
Thanks Rick G. |
1 Attachment(s)
[ATTACH=CONFIG]545745[/ATTACH]
Originally Posted by 14 apache
(Post 4359257)
| All times are GMT -5. The time now is 10:58 PM. |
