-   -   docking (https://www.offshoreonly.com/forums/general-boating-discussion/331745-docking.html)
kevin murphy 10-18-2015 07:31 PM
docking
hey guys, I had a 32 sunsation the props spun out. I could darn near zero turn one forward one reverse, easy to dock. Just got a 38 donzi the props spin in. It is all over the place i can't control it. Please any sugestions. Thanks
nailit 10-18-2015 07:39 PM
Spinning IN, you lose reverse thrust. I noticed it immediatly when I switched mine to IN and tried backing off trailer.
Try lifting your drives a lil above neutral, it should get the thrust below the boat instead of hitting transom.
14 apache 10-18-2015 07:46 PM
Make sure you trim the drives up or most of the water will hit the transom. It happened to me when the drives where trimmed down,
seafordguy 10-18-2015 07:49 PM
Where are you from? I know someone with that name in my area, but imagine its coincidence.
Unlimited jd 10-18-2015 08:01 PM
A little bump of the throttle and wheel input goes a long way. I have a lot of hours docking a 38 donzi, gets easier.
If you want the transom to go to starboard turn right, port reverse, stbd forward and use a little port throttle. Trimming drives slightly above neutral helps also.
kevin murphy 10-18-2015 08:36 PM
Michigan
we are about in the middle of the state
kevin murphy 10-18-2015 08:47 PM
Thanks , when you say above neutral, drives up 1/4 ish? I can't wait to try. We only spent one weekend and had to pull it fof the season. I felt like a jerk trying to dock it.
Sydwayz 10-19-2015 12:23 AM
What size/model Donzi is it? Is it a staggered setup or side by side?
rak rua 10-19-2015 06:06 AM
Spot on, you've nailed it.
Lots of trim, especially if it's a notched transom. The wash from the reverse prop just hits the notch and pushes the boat forward. Have a look when it's out of the water and imagine a line from the prop shaft showing where the thrust is aimed. Trim your engine up until that line goes under the transom or notch.
A little steering in the direction of the turn also helps but remember to straighten her up after!
RR
Feverz29 10-19-2015 06:53 AM
Kevin, when did you get your boat, do you boat on Saginaw Bay? Chris
kevin murphy 10-19-2015 08:14 PM
got it the week before labor day. and only had it in lake michigan muskegon to grand haven and back.
kevin murphy 10-19-2015 08:22 PM
shogren marine il., the boat was from ohio. we are close to lake michigan so muskegon grand haven. for the most.
kevin murphy 10-19-2015 08:24 PM
38zx they are side by side 525's all stock.
kevin murphy 10-19-2015 08:43 PM
mich. north of grand rapids about 35 miles
kevin murphy 10-19-2015 08:45 PM
38zx side by side stock 525's
glassdave 10-19-2015 10:07 PM
ya get use to it but yeah that boat sucks backing in. I actually just got good at using just one lol, had a 99 38ZX for ten plus years, sold it little over a year ago. Wonder if its my old boat. What year is it and what color?
