-   -   Clamp-on billet throttle mounted trim switch (https://www.offshoreonly.com/forums/general-boating-discussion/332459-clamp-billet-throttle-mounted-trim-switch.html)
johnmiffco 11-16-2015 04:53 PM
u can get the mercury "trim on handle" switches on line that fit them controls
that's what I did when added trim switches
mercury oem parts are available for them controls
MarineEngines.com is where I got mine
trim switch kit and the diode kits for twins or trips
RaggedEdge 11-16-2015 05:27 PM
I may have one like that one you pictured, If you are not in a real yank to get this I will look thru the parts bin to see if it is there. If it is you are welcome to it. Give me a bit to look, I will get to it.
I will look in the next couple days, if I have it, it's yours! Only for a Fountain guy!
89Mach1 11-16-2015 05:42 PM
Wow, that's very generous of you, thank you! I have all winter, so take your time. Where bouts in NY are you? I'm on the north shore of Oneida Lake but we have a camp up in A-Bay that we are at most weekends of the summer.
89Mach1 01-11-2016 12:09 AM
4 Attachment(s)
Well, I never did find exactly what I was looking for, and mercs cheap plastic trim in handle kit just wasn't doing it for me. So... I made my own. Aluminum housing, polished to match freshly polished throttles. If anyone is in need of the same I'd be happy to make more of them for a fee.
MnFastBoat 01-11-2016 12:52 PM
http://www.rexmar.com/page40.html
and I just re-read your post and now the LH stood out :)
Originally Posted by 89Mach1 (Post 4376181)
Does anyone know where I can buy this? Need the one pictured for left hand throttle. Can't find one from the part number. Anyone have an extra? Thanks
murfman 01-11-2016 03:17 PM
What are you going to do for the wiring? I used a piece of 3/16 Stainless tubing, drilled a hole in the knob, fit the tube into the hole and Tig welded it to the bottom of the lever, after grinding the edge off the lever so the tube didn't interfere with WOT.
http://i184.photobucket.com/albums/x...ps6cac3912.jpg
After polishing and assembly
http://i184.photobucket.com/albums/x...ps92gryae5.jpg
I have since blacked out the Formula script on the switch as this is going on my Magnum. I bought the switch from here http://greatlakesskipper.com/baja-fo...ol-trim-switch I'd still like to add a clamp on twin switch for my tabs.
johnmiffco 01-11-2016 03:57 PM
1 Attachment(s)
the merc plastic copied in allun turned out really nice
the tube is how it comes from merc also
I was lazy and just bought the parts,,, lever and trim switch assy lol
turned out nice in red
this is when I was doing resto on boat
blue cables go to indicators that I made a box to mount on top of dash as no room on dash to hide cables
also made a plate to go under throttles to hold my k plane switches
for easy acess to them
[ATTACH=CONFIG]549544[/ATTACH]
89Mach1 01-11-2016 09:50 PM
Basically doing the exact same thing! I ordered some 3/16 stainless and plan to drill a hole like you and tig it at the bottom. What type of drill bit did you use?
Wildman_grafix 01-12-2016 06:59 AM
Well mine were different, they already had the tube built in so it was just add a dual switch. First time I got lucky on something, better go buy some lotto tickets.
https://farm2.staticflickr.com/1511/...e531312e_o.jpgIMG_1639 by WIldman Grafix, on Flickr
https://farm2.staticflickr.com/1526/...0a0d27f3_o.jpgIMG_1657 by WIldman Grafix, on Flickr
https://farm2.staticflickr.com/1670/...e044338d_o.jpgIMG_1658 by WIldman Grafix, on Flickr
murfman 01-12-2016 09:58 PM
Just a HSS 3/16 bit with cutting oil and a nice slow speed
