Both my bilge blowers melted >
Old 07-22-2016, 04:46 PM
Default Both my bilge blowers melted
And they did it in sequence. Wtf?
Had the blowers running last weekend and I started to smell that burning electronics smell. Oh $hit. Popped the hatch and one was smoking so I turned them off and began to investigate. One was smouldering and the other had a large black hole burned in it.
What the hell?
Cole2534 is offline
Old 07-22-2016, 06:48 PM
There has got to be more to this story -- were there any mice in the blower area? Is it possible that you may have put 24V to both instead of 12V?
Please keep us informed what happened
3pointstar
3pointstar is offline
Old 07-22-2016, 09:50 PM
did the pumps try to pull water?
Ryan
Ballistic Beak is offline
Old 07-22-2016, 10:09 PM
Ryan
No
3pointstar
No way 24v was hooked up to them, they've never been messed with to my knowledge.
Also, can a mod move this to boating general discussion? I'm not sure how it got here.
Cole2534 is offline
Old 07-22-2016, 10:40 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
I moved it for you.
Are you certain they didn't get wet somehow, not even water splashed in the output vents when moored?
Sydwayz is offline
Old 07-23-2016, 12:26 AM
they could get hot because they never get lubricated. I have drilled a hole and dripped oil on the shaft. But looks like you're getting some new ones
mcprodesign is offline
Old 07-23-2016, 02:07 AM
Originally Posted by Sydwayz
I moved it for you.
One i can't say for sure, but the other i know for a fact didn't get wet.
Cole2534 is offline
Old 07-23-2016, 11:20 AM
Were they the atwood in line blowers? If so, i have had a couple of those melt down for no apparent reason. Attributed it to time in a wet enviroment. The replaced them with a jabsco unit.
flatlanderbill is offline
Old 07-23-2016, 11:48 AM
BUP
The jist
Fuse protected ? What size fuse ?
Dirt dobbers like to nest in them and or in the hose ducks
restrictions in the air ducts or vents and or again nests of some sort built in them or ducking from whatever ie animals - dirt dobbers, rats I have even stuck in them.
plastic bags or whatever gets sucked up into them or the hose ducking - check for any restrictions.
next when blowers turn on, the end vent hose portion can get sucked up against anything - the bilge floor, a stringer, a bulkhead or whatever creating a total restriction of air movement thru the blower inwhich causes them to run very hot. very common - the reasons installed vent hoses improperly or to long or end of vent hose not sucured in place that gets sucked up against whatever when the blowers are turned on,
or the vent hoses collapsed
Most of the time its installer problem that caused this for brand new installs that fail in short order.
or a wiring problem or fuse problem ie voltage problem of some sort as well
BUP is offline
Old 07-23-2016, 12:15 PM
SB
Received 3,115 Likes on 1,402 Posts
I moved it for you.
I've seen them mounted in a spot (bottom of slight U or L) where water collects in them. I'll know it first hand when someone turns their blower on and you hear a slight gurgle of water.
SB is offline
