-   -   Impellers Sitting For 2 Years - replace? (https://www.offshoreonly.com/forums/general-boating-discussion/334009-impellers-sitting-2-years-replace.html)
BajaFresh 01-24-2016 02:11 PM
Looking at a boat that has been sitting for 2 years. Impellers were replaced before the boat was put up. Okay to run them or should they be replaced?
mike tkach 01-24-2016 02:14 PM
depends on your luck,do you feel lucky,if not change them and go boating.
Bawana 01-24-2016 02:24 PM
By looking at your location, I would back the boat in the water, leave it on the trailer, start the boat and see. I know guys that have the same impellers in their boat for 10 years. I scratch my head and think, why can't I be so lucky. I have also seen guys put new impellers in their boat every season. I have water pressure gauges for my motors and replace them when I see a drop in pressure. You can look at it as .. if it aint broke don't fix it. Or replace them now and not worry about it. But then it can be said why stop at the impellers? What about springs, rings... etc. Where do you stop?
3pointstar 01-24-2016 02:35 PM
If you gamble there is a slight chance they they could be brittle. Then you start the engine and parts of it break off and get lodged in always an orfice that is too small and hard to reach. Those always are expensive. Look at it this way the modest price to replace before you start can sure offer a huge piece of mind
3 pointstar
Bawana 01-24-2016 02:51 PM
3 pointstar brings up a good point. So let me add that anytime you replace an impeller you should back flush your system. Even if all the impeller parts are there, other stuff can and does get caught in the coolers. I flush them by filling up the system with water, and with the hose off the sea pump, I use a special fitting I made, and blow about 80psi air through the system, forcing the water and air out. I do this a couple of times.
Wildman_grafix 01-24-2016 03:04 PM
Un
That sounds like a good idea, where are you hooking the air up to?
Bawana 01-24-2016 03:13 PM
Originally Posted by Wildman_grafix (Post 4396786)
Un
At the end that connects to your cross over/thermostat housing. But make sure the other end (connecting to the sea pump) is disconnected. And by putting water in the system at the end that connects to the cross over/thermostat, with the air will unplug the honeycombs in the coolers. I made a 1.25 fitting with a on/off valve with an air chuck fitting that I just hose clamp into the end.
Bawana 01-24-2016 03:23 PM
I must add that throughout the years of using my flushing tool/method, the junk& crud that comes out is unbelievable . I have had people come to me with issues that when they ran hard for any extended time, that their motor temps would start to climb a little. Well 99% of the time it was because of blockage in the system/coolers.
Indy 01-24-2016 03:39 PM
Change them, it's cheap insurance. I'd rather be boating than f'ing around getting a tow back and screwing with the back flushing hassle.
cigrocket 01-24-2016 03:49 PM
Cheaper to replace the rubber impeller, rather do that then scower the housing and have to replace the pump housing. Simple to do, one last maitinance item and you have a baseline
flatlanderbill 01-24-2016 03:58 PM
Not to mention tbe slow, boring ride home on 1 engine when it fails and wondering if the other one will last long enough to get back to the lift / trailer.
BajaFresh 01-24-2016 05:46 PM
I guess I'll swap 'em out. I'll be making runs to Catalina, 40 miles out, so don't want to risk it. Like you all said, cheap insurance.
Drives and motors were serviced before it was put up but will probably change the oil anyway.
It has 7.4 Mags with 320 hours.:flag: (How come there is no thumbs up smiley face?).
Thanks for the advice.
mike tkach 01-24-2016 06:10 PM
good info here,i had a boat in the shop recently for a coupler replacement,the owner was telling me he had a shop replace the wp impeller because the water temp was getting hotter than normal,he said it was still getting hot even after the impeller replacement.i had the engine out so i decided to check the coolers for debris,the ps cooler was packed full of broken&burnt up impeller pieces and what looked like sea shells,it was so bad i don,t know how any water was flowing past the cooler.
class6 01-24-2016 06:39 PM
I would run the boat a day or 2 to see if there's other things to put on the list. Just go run it local
bulletbob 01-24-2016 06:42 PM
Your will have to change your title to Bajablown if you don't change them. I just ran 44 miles at 82 mph with fresh impellers in 48* air temp. Change your impellers. Cheap insurance. Good luck if you don't!
speicher lane 01-24-2016 07:43 PM
One tow would probably cover the cost of replacing the impellers....Once you puke the impellers, keep the wallet open for the extra work to clear the coolers... assuming the tech's get all the shards out and that is the end of the cooling problem.
Even if they do not disintegrate, after sitting for 2+ years, they will have taken a set shape and are no longer efficient = new impellers are required.... change them out and reset the clock back to "0" hours and go boating w/o worry!
Jupiter Sunsation 01-24-2016 07:51 PM
Heading to the Catalina Wine Mixer?
Being that is a salt water run, I would change the impellers, the anodes, the batteries, the gimbals, the props, the prop nuts, the trim tabs, the rub rail and all the deck hardware just to be on the safe side! :D
https://www.youtube.com/watch?v=mfhT2pPXqBA
tmmii 01-24-2016 08:26 PM
2 pages over $60 worth of parts?
Wildman_grafix 01-24-2016 08:33 PM
Thanks I am one that would rather do preventative then repairs. Always seem cheaper in the long run.
Indy 01-24-2016 08:34 PM
Changing the impellers is just about the cheapest thing you can do when it comes to boating, I changed mine every spring without fail.
Griff 01-25-2016 01:17 AM
They are probably ok, but I'd change them for peace of mind.
cigrocket 01-25-2016 07:33 AM
62.50 + tax......lol
TBAG 01-25-2016 08:18 AM
It's winter..........
offshore312 01-25-2016 10:35 AM
Heck, now it's three pages with the added $2.50 in tax... I'll bet we get it to four pages after we include the shipping... :party-smiley-004:
dmaxximus 01-25-2016 10:59 AM
Change, it's not even worth the risk. Iv'e had them break apart and pieces get caught in the hoses blocking the water from cooling. If they look in good shape after you remove, keep onboard for a spare. Just my .02
cigrocket 01-25-2016 11:00 AM
1 Attachment(s)
Of course, I forgot about shipping. Free shipping if you spend $100. Ha Ha.
Installation is also extra and the thread grows.[ATTACH=CONFIG]550105[/ATTACH]
You could always save a little and find one on craigslist. The above should work
3pointstar 01-25-2016 12:41 PM
My replacements are just like this but not as nice. Do you think the extra groves improve speed and therefore overall HP??
Indy 01-25-2016 12:47 PM
Definitely, less rotating mass.
BUP 01-25-2016 01:33 PM
Just saying in a good way - this sould not even be a question when owning a boat.
All impellers that sit for X amount of time - the impeller blades form a folded over set that does not bounce back inwhich reduces cooling and water flow volume. Also the blades become brittle - they can tear at start up and when one blade breaks off completely the rest will follow like a domino effect.
Even if your app is pumping water, it still is at reduced levels inwhich you are only asking for trouble.
twinscrews 01-25-2016 03:16 PM
Change
class6 01-28-2016 01:34 PM
Put a blue one in
