-   -   Moisture meter for inspections (https://www.offshoreonly.com/forums/general-boating-discussion/334300-moisture-meter-inspections.html)
Flightplan 02-04-2016 02:15 PM
1 Attachment(s)
How effective are these pinless moisture meters for detecting wet transoms and stringers.
This should work through Fiberglas. Right? Shows depth of 1.6".
http://www.extech.com/instruments/pr...=11&prodid=631
[ATTACH=CONFIG]550534[/ATTACH]
class6 02-04-2016 02:22 PM
Ohm meters can work well also, take out a few screws inside engine compartment and stick the probes right in. if its wet it will tell you,
northernoffshore 02-04-2016 03:19 PM
thermal style ones work good... i have a skipper plus
Griff 02-05-2016 12:42 AM
I highly doubt the one pictured will work through fiberglass, at least not accurately.
Its for building/construction materials http://www.extech.com/instruments/re.../MO257data.pdf
