-   -   External exhaust flaps (https://www.offshoreonly.com/forums/general-boating-discussion/335765-external-exhaust-flaps.html)
pro27 03-23-2016 06:28 PM
Anyone use Hardins stainless external exhaust flaps.Was wondering how they hold up,I ordered a set but was wondering if anyone has tried them.
Wildman_grafix 03-23-2016 06:30 PM
Search in the fountain area I think the guy with a trip 47 used them.
1989mach1 03-23-2016 06:55 PM
I bought Them off the guy with the fountain this winter. I have not had any run time with them yet but I can say this. They look a million times better then the rubber ones.
[IMG]http://i1149.photobucket.com/albums/...ps3ugbrvqc.jpghttp://i1149.photobucket.com/albums/...psvbj77ds7.jpg[/IMG]
pro27 03-23-2016 07:18 PM
Nice looks good
Jparanee 03-23-2016 07:53 PM
I just added the internal flaps version from Hardin and so far I like the look
http://i200.photobucket.com/albums/a...D4294021EF.jpg
pro27 03-23-2016 09:22 PM
Can't really see them under my swim platform,so not really going for the look,although it is important.I am looking for something that will hold up to heat and keep water out
HyFive578 03-24-2016 08:53 AM
Yes, that would be me. They hold up great and look great. I removed them because I was continuing to have reversion issues with my rear engines. This was complete speculation but there was a possibility that the flappers were trapping some water due to their weight by not opening sufficiently under idle exhaust pressure. Not saying the flappers are the cause but I am trying to eliminate any and all contributing factors.
pro27 03-24-2016 09:31 AM
Thanks for the reply,I shouldn't have that problem mainly looking to see how they hold up
Tom A. 03-24-2016 10:15 AM
I have the rubber ones and they work great but don't look great.
My question is do the rubber o rings on the stainless ones really keep them from making a clinking noise as they bounce open and closed?
I have a few trucks at work with the stainless flappers on the stacks and all you hear when they are idling is clank, clank,clank.
VoodooRob 03-24-2016 11:50 AM
2 Attachment(s)
[ATTACH=CONFIG]552877[/ATTACH][ATTACH=CONFIG]552878[/ATTACH] The Stainles flappers are nice quality and do not make any clanking noise. The gasket works to eliminate that. The design is an easy one bolt clamp on, BUT if you tighten the bolt too much the flappers will bind. A couple of the flappers were binding right out of the box, so I took then apart and clearanced just slightly at the moving joint. Much better looking than the rubber external flappers but also much more expensive.
Ryan00TJ 03-24-2016 08:15 PM
I agree. I bought the third pair from Hyfive. Can't wait to try them out.
http://i77.photobucket.com/albums/j7...320_165608.jpg
1989mach1 03-24-2016 08:38 PM
The rubber ones got really dirty and hard to clean on my boat because they are always half or more under the water when stoped or at idle. This was taken leaving the dock to go to the starting spot for a poker run[IMG]http://i1149.photobucket.com/albums/...pspsx4tr4c.jpg[/IMG]
